Redirect using Cookie value
Thread begun 6/19/2014 9:30 am by Andrew Dodd - ADDIGITAL | Last modified 6/21/2014 9:20 am by Jason Byrnes | 4067 views | 13 replies |
Hi all,
I am trying to redirect a user to a registered page if a cookie is set, but for the life of me, I can't get it to work.
I've attached the onload behaviour to the body tag to check and the set cookie behaviour to the form later on in the page, and I thought I'd cracked it. But it still doesn't work.
I know there was a discussion about this way back in 2009, but things have changed dramatically since then.
The page is at http://www.simplyfetes.com - can another pair of eyes see what I can't?
Andrew
add the following script tag to the page:
<script src="webassist/cookies/cookies.js"></script>
Thanks Jason! I knew it would be something simple!
Andrew
You're welcome, I have logged a bug that the script is not being added.
Hi Jason,
Slightly off topic, but now that we've fixed this, my server validations have stopped working. The name is required etc - the validation ShowIf aren't firing either.
Can you help?
I attach updated index.php.
Sorry to be a pain!
Andrew
Info moved to PM
you have multiple instances of the server validation server behavior.
there should be only one instance of the server validation server behavior on the page, with all of the validations defined in the one server behavior.
you should remove the server validation and validation show if behaviors from the page, then recreate them using only one server validation server behavior.
See PM
No Worries Andrew
