Connection Error
Thread begun 6/17/2014 11:23 am by PrvtPilot | Last modified 6/17/2014 1:28 pm by Jason Byrnes | 3755 views | 5 replies |
PrvtPilot
Connection Error
When i try to create a connection I get this:
http error code 401 unauthorized
These same connection settings work fine in CS3 but will not work in the WebAssist Connection settings
Any ideas?
The MySQLi server behaviors is not supported in Dreamweaver CS3
http://www.webassist.com/product/mysqli
Runs on: Dreamweaver CS4, CS5, CS5.5, CS6, CC
PrvtPilot
Let me rephrase,
I am using WebAssist in Dreamweaver CC
When I attempt to create a connection i get this error: http error code 401 unauthorized
I know the connection information is correct because I can establish connections to the database in other programs.
Double check the site definition, specifically the settings for the testing server, and make sure they are the same in DW CC as they are in DW CS3 for the site.
PrvtPilot
The problem is that the entire website is protected by an .htaccess file. The connection works fine if I remove that file.
I can work around this for now but when the site goes live I cant remove the .htaccess file. Is there a workaround for this?
what ever in the htaccess file is preventing the database connection would need to be removed.
