What php configuration settings should we use for compatability with WA generated pages? Our host switched servers & now our pages don't work.
Thread begun 6/17/2014 10:56 am by lennon59 | Last modified 6/17/2014 1:06 pm by Jason Byrnes | 2047 views | 4 replies |
lennon59
I tried to see the config using phpinfo(). Shows a blank page. No way to change config on control panel, so I need config setting to send to support. Version is 5.3.27. The pages that don't work are all login pages. Nobody can login now.
that all depends on why the pages don't work.
lennon59
lennon59
Originally Said By: lennon59
this has nothing to do with PHP settings.
For 1, this is using the standard DW login / registration behaviors which we don't support. Support for the built in Server behaviors in DW should obtained from Adobe.
for 2, both the admin/index and account/manage/index.php pages are set to use user level authentication based on the MM_UserGroup session being set to 2 or 3
The login page however is not set to give any value to the MM_UserGroup session besides "":
$loginStrGroup = "";
//declare two session variables and assign them
$_SESSION['MM_Username'] = $loginUsername;
$_SESSION['MM_UserGroup'] = $loginStrGroup;
first:
then:
this code will mean that the usergroup session is always empty.
