Datepicker on Update page isn't highlighting the predefined date.
Thread begun 6/16/2014 12:25 pm by troyd | Last modified 6/23/2014 10:46 am by Jason Byrnes | 3605 views | 6 replies |
troyd
In all my older uses of datepicker inserted with DA, the flyout calendar will preselect the date in the database. I am referring to an update form here.
But newer use of the datepicker isn't working for some reason.
I manually added the value to the form field as always. And the textfield populates just fine with the date in the db. But the flyout calendar only selects Today's Date. Did something change or am I overlooking the obvious? I'm not sure this is a standard behavior in the datepicker so maybe I did something custom before to make it work and I'm just not finding it. Any thoughts on what I should try?
Thanks,
TroyD
troyd
Jason, I just saw this, sorry.
Most of the online versions are older DA applications and they all work as expected. I have one live admin section that doesn't but it's not one I can give access to, as per my client.
Let me setup something simple on a live domain and I will PM you the details.
Thanks,
TroyD
Ok, let me know when that is ready
troyd
Jason,
Well...I setup an online sandbox using a subdomain so that nothing else was included but the minimal files, and it works just fine. Go figure.
The date in the database is highlighted in the update form's datepicker just as it should be.
So now, I know it has to be a conflict with something in my newer applications. Maybe some of my custom JQuery or CSS. Not sure yet but I will let you know once I figure it out.
The funny thing is I stripped out all my CSS and JQuery to test for this before posting this issue but I must have overlooked something. I am going to add to this clean setup, little by little until it breaks the datepicker. Once I find the culprit, I will go back to my other applications and see if that fixes the problem.
Also please see private message.
Thanks,
TroyD
troyd
[Solved]
I believe I figured this out. I had included a customized version of the JQuery UI on Themroller. jquery-ui-1.10.3.custom. (or jquery-ui-1.10.4.custom).
This wouldn't have normally been a problem but it looks like there is a small error in the JQuery style sheet where it references an image. The background image used to highlight the active date.
They named the image I was using, ui-bg_flat_50_657A99_40x100.png but the style sheet references ui-bg_flat_50_657a99_40x100.png. The small "a" in the name of the image url should be a capital "A". So that causes the effect to break visually.
So this wasn't an issue with the WA files at all. But I wanted to post my finding here in case someone else comes across this problem, although this might be somewhat localized.
(Jason. If you haven't read my previous PM, please take a look at it for me.)
TroyD
Glad to hear it is working
