Open a new window on redirect
Thread begun 6/14/2014 12:22 pm by derekmparker375520 | Last modified 6/17/2014 1:00 am by CraigR | 5451 views | 7 replies |
derekmparker375520
I have a form set up that redirects the user to a different site after submitting the form. Is there a way to open this page in a new window?
CraigRBeta Tester
PHP is server-side.
A new pop-up window is client-side.
Usually this is done with either the target="_blank" attribute in a link, or with javascript using window()
I suppose you could set your php redirect with a get parameter, and use this condition to trigger a script
if (isset($_GET['popup'] )) { ?>
<script>
window.open("page name", $other_attributes_here );
</script>
<?php } ?>
derekmparker375520
Thanks for the reply. I'll give this a shot but I'm not sure where to put this in the code, could you help me out with that? I have the page attached to the previous post.
CraigRBeta Tester
PM
derekmparker375520
See PM
CraigRBeta Tester
PM (if required)
If you change your form, so the redirect points to a new (internal) page, lets say external.php.
set the redirect url as follows... /external.php?popup=true
create a new page called external.php, add the following code within the <head></head> tags
if (isset($_GET['popup'])) { ?>
<script>
var win = window.open("http://google.com", '_blank');
win.focus();
</script>
<?php } ?>
changing the url to the one you need
This should work as long as the browser doesn;t have popups blocked
derekmparker375520
That worked perfectly but there was only one problem. The issue is that the page containing the form (needs.php) has instructions for the site that they're redirected to. So I need the needs.php page to remain open so that they can reference that but it's showing external.php.
CraigRBeta Tester
A couple of things spring to mind.
1. Instead of redirecting to a new internal page first, just redirect the page to itself, but include the url parameter in the redirect, then add the conditional javascript in the head section.
2. If this doesn't fulfil your needs, can you store whatever values you need in a session variable ?
