CMS builder
Thread begun 6/13/2014 9:28 pm by Webbie | Last modified 7/28/2014 3:11 pm by Jason Byrnes | 2753 views | 6 replies |
Webbie
CMS builder
I keep getting an error that says : While executing caninspecSelection in waskype_button.htm, a JavaScript error occurred
Have you ever heard of this? any way to fix?
Thanks!
Webbie
I figured that one out, i was think it was because i was trying to put a CMS content section from two editable region erea's all at once. I took it one editable region at a time and not getting that error!
Glad to hear you found the problem.
Webbie
Trying to edit a nav menu that i put in power CMS, but cant figure out how to give it the text i inserted padding to so the buttons match menu.
I attach a picture and link.
See the eCommerce button there? i know how to fix in dreamweaver just not with tools in powerCMS.
Is there a way to adjust the padding?
if you view source of the other links, they have a span tag around the link text:
<a href="harddrive_shreddingandsanitation.php"><span>Hard Drive Recycling</span></a>
edit the eCommerce link and add a span tag around the link text as well.
Webbie
Your brilliant,
Thank you
you're welcome.
