Email sending issues.
Thread begun 6/12/2014 7:15 am by akstudio | Last modified 6/12/2014 10:47 am by Jason Byrnes | 5563 views | 16 replies |
akstudio
So, I'm on Rackspace, and have had issues with email not going out via PHP. The client tells me they have their own email server, and he sets me up with an account so I can relay email through it.
On the surface, this works.
Here is the working script:
require_once "Mail.php";
$from = "them@theirdomain.net";
$to = "me@mydomain.com>";
$subject = "Test email using PHP SMTP\r\n\r\n";
$body = "This is a test email message";
$host = "hostname";
$username = "username";
$password = "password";
$headers = array ('From' => $from,
'To' => $to,
'Subject' => $subject);
$smtp = Mail::factory('smtp',
array ('host' => $host,
'auth' => true,
'username' => $username,
'password' => $password));
$mail = $smtp->send($to, $headers, $body);
if (PEAR::isError($mail)) {
echo("<p>" . $mail->getMessage() . "</p>");
} else {
echo("<p>Message successfully sent!</p>");
That works.
Now, when I put this into Universal email (I left the "path to PEAR blank) No emails are being sent.
I had to setup a separate "insert record" to capture the form data, as this is business critical for the client. I've tried a lot of different settings etc in UA, including allowing it to write to the DB, both for success and / or failure. This wont work either. Because that functionality won't work, I can't see what the "status" or "error" is.
So, we know the email works with the above script, but not with UA is there something I should be looking at or a method to help troubleshoot this issue? I'm using data bridge 1.1.8
Does the client need to "add me to a group" or something else? I do recall when we were testing the above script, it would error out a few times, until he added the email in and allowed the IP. They us Exchange, BTW.
In the webassist/email folder delete the mail_php.php and mailformatting_php.php files, then edit the UE behavior to recreate them
for the From address, make sure to use a valid email address for your domain, and leave the go to page blank for now.
then add the following codse at line 1 to turn on error reporting:
error_reporting(E_ALL);
ini_set('display_errrors','on');
and this code in the page body to write the session contents:
<?php var_dump($_SESSION); ?>
the session contents will contain the success or failure for the email for troubleshooting.
akstudio
array(9) { ["emaillog"]=> int(26) ["WAUE_customer_service_1_Status"]=> NULL ["WAUE_customer_service_1_Index"]=> NULL ["WAUE_customer_service_1_From"]=> NULL ["WAUE_customer_service_1_To"]=> NULL ["WAUE_customer_service_1_Subject"]=> NULL ["WAUE_customer_service_1_Body"]=> NULL ["WAUE_customer_service_1_Header"]=> NULL ["WAUE_customer_service_1_Log"]=> NULL }
Hmmm. Let me think for just a minute....
Everything is null, and Ive received no email
akstudio
OK
OK thanks
akstudio
PM sent
PM sent
see PM
akstudio
see PM
see PM
akstudio
PM
