DataBridge 1.1.9.
Thread begun 6/10/2014 6:44 pm by Vikingbear | Last modified 6/12/2014 7:44 am by Jason Byrnes | 1720 views | 3 replies |
Vikingbear
DataBridge 1.1.9.
Hi, just upgraded DataBridge from 1.1.3 to 1.1.9 and Dreamweaver CS6 still crashes when I try and use DataBridge..
I have previews turned off, I do not use any templates, I step very slowly through each process and still it crashes??
WIN8.1 64bit on i5-3337U 1.8GHz and 8GB RAM
Anybody solved this issue as yet??
Are you using one of the Application presets or having Data Bridge create the table for you? or using the New From Blank preset and using your own table?
if using your own table, please provide the table structure.
When Data Bridge crashes it is usually due to a memory leak in DW. after it crashes, you should restart the OS to release the memory, and Delete the Dreamweaver Cache file from the users configuration folder:
Vikingbear
DataBridge 1.1.9.
Hi Jason, Thanks for your reply..
I am using my own table (a tiny 3 field table - screenshot attached)
I have preview turned off and no presets/templates
I was chatting to Ray a few months back via Skype when I had teh same issue with 1.1.3 and he sent me a small file to 'update' the plugin, but I suspect that is included in the 1.1.9 version.. and it did not fix the issue but made it less frequent..
I was able to get the odd process working, 1 in 5 or 6 attempts with 1.1.3 but so far with 1.1.9 I get a crash each time..
I make sure that I only have DW running, no other applications that can hog my RAM while I am using DataBridge but alas.. :(
I'd upgrade my RAM if I knew for sure that would fix the issue, I run Photoshop and Premiere on the laptop with no issues..so 8GB seem to be enough!
did you Delete the Dreamweaver Cache file from the users configuration folder:
where you installed an update form a previous version., you clear the DW cache.
