How do i change the color of the main link of the menu's?
Thread begun 6/10/2014 4:29 pm by Webbie | Last modified 6/11/2014 8:01 am by Jason Byrnes | 1247 views | 1 replies |
Webbie
I know how to change the other layers as that is simple but should i be creating my menu's in Photoshop or something relative and then bringing them in to to css menu writer through the file-name area?
I don't see any tutorials on this but i need to know as i cant just put up an almost similar to color menu and say good enough.
Please elaborate
Thanks!
That depends on the menu type you are using.
If you are using a menu type that uses images, you need to create images for the menu that use the color you wish to use.
if you are using one of the menu types that does not use images, then you can change the color within menu writer.
