file not uploading - universal email & dataassist
Thread begun 6/10/2014 1:26 pm by Kumel | Last modified 6/17/2014 8:11 am by Jason Byrnes | 8523 views | 30 replies |
Kumel
I had created data assist pages. All seemed to be fine. But i tried adding file upload it. File isn't uploading in server(folder) neither is data entering in mysql DB.
I worked as per Tutorial provided. But still i m not working. Please help me out. form is already having multipart/Form-data.
Regards
I'm assuming it's the insert page that is having the trouble?
to troubleshoot:
add the following code at line 1:
error_reporting(E_ALL);
remove the redirect from the isert behavior by changing:
$WA_redirectURL = "blog_Detail.php";
$WA_redirectURL = "";
then in the body, add the following code to write the file upload debug info and the insert SQL:
<?php if (isset($_POST["Insert_x"])) { ?>
<?php echo($WA_Sql); ?>
<?php echo WA_DFP_AllUploadsDebug(); ?>
<?php } ?>
post back the result after trying the insert again.
Kumel
received this error :
Warning: move_uploaded_file(images/blog//5d3d48b06014a1447fe3a5318bde6d77_tmp.jpg): failed to open stream: Permission denied in /Applications/XAMPP/xamppfiles/htdocs/nextgen/webassist/file_manipulation/helperphp.php on line 94
Warning: move_uploaded_file(): Unable to move '/Applications/XAMPP/xamppfiles/temp/phpC15IsZ' to 'images/blog//5d3d48b06014a1447fe3a5318bde6d77_tmp.jpg' in /Applications/XAMPP/xamppfiles/htdocs/nextgen/webassist/file_manipulation/helperphp.php on line 94
Warning: copy(images/blog//5d3d48b06014a1447fe3a5318bde6d77_tmp.jpg): failed to open stream: No such file or directory in /Applications/XAMPP/xamppfiles/htdocs/nextgen/webassist/file_manipulation/helperphp.php on line 96
INSERT INTO `blog` (`id`,`title`,`short_description`,`long_description`,`img`,`date`,`month`,`name`) VALUES (NULL,'','','','','1','Jan','')Status object: WA_UploadResult1
statusCode : -1
errorMessage :
clientFileName :
fileExtension :
serverFileName :
serverSimpleFileName :
serverDirectory :
contentType :
fileWasOverwritten :
fileWasSkipped :
fileWasRenamed :
fileSize : -1
isImage :
imageWidth : -1
imageHeight : -1
WA_UploadResult1_1:
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileSize : -1
imageWidth : -1
imageHeight : -1
this means that the upload folder does not have the proper permissions to allow an uploaded file to be saved
edit the permissions for the upload folder to 777
Kumel
So how do i do it exactly?
file is not uploaded as well as data also not inserted of img field.
Kumel
I tried changing folder settings to read & write. Now everything works. But how to do it from web end?
use file zilla or another ftp program to access the site files.
in file zilla, you can right click on a folder and select File Permissions to change permissions for the folder.
i understand that it is not uploading the file or saving the file name to the database, that is because the permissions for the upload folder are not allowing the file to be saved.
Kumel
well ok. thanks a lot.
by the way i need to change above settings to :
right?
cause i end up getting error. & i stay in same page. so
after you fix the file permissions, you revert the changes, they where only for troubleshooting.
Kumel
Thank You :)
