corrupt downloaded files can't be opened
Thread begun 6/09/2014 11:10 am by asarcona308398 | Last modified 6/10/2014 9:26 am by Jason Byrnes | 3922 views | 8 replies |
asarcona308398
Hey Guys,
I've another dilemma...
I'm using DataBridge to download .jpg or .png files.. they seem to be downloading locally and naming ok, but are unable to be opened.
I have attached the file...
the Download Behavior is on line 478...
the button and form are at 784
thanks for your help
Tony
change the form tag:
<form action="" method="post" enctype="multipart/form-data">
<form action="<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""; ?>" method="post" enctype="multipart/form-data">
asarcona308398
see pm
asarcona308398
I applied changes...no luck...
asarcona308398
Jason I noticed this in the forum:
In the 2 previous instances of this problem is was being caused by corruption in some of the files. Specifically it was a problem with extra blank lines being added to the web assist helper files on upload.
this is normally caused by the FTP program being used to upload the files using the Binary transfer method instead of using the ASCII transfer method.
Just so you know, all the files we're trying to work with were uploaded via DFP / DataBridge.
The FTP info you sent for me does not allow for me to make edits to the page.
But, by turning on visual aids to show invisible element:
View -> Code View Options
Check the Hidden Characters options, I can see that there are a number of placed on the page where there is a space between closing php tag:
and opening php tags, see the attache screen shot for an illustration. in the screen shot, spaces are denoted by dots with hidden characters displaying and line feeds are denoted by backwords p's
you need to remove all instances of spaces, or empty lines between closing php and opening php tags.
asarcona308398
Jason,
In Code View I used the "Format Source Code" button on the left side toolbar and selecting "Apply Source Formatting"
And It Works!!
I found this process at:
https://forums.adobe.com/thread/1051264?tstart=0
Thanks for the Always Excellent solution,
Tony
Glad to hear you have it working.
