carriage
Thread begun 6/09/2014 5:16 am by Jamie | Last modified 6/10/2014 9:07 am by Jason Byrnes | 2220 views | 5 replies |
Jamie
carriage
Hi Jason
Am struggling to get carriage costs added to a cart. I have got the attached set up in the ecart onject but not sure if its correct? Basically am trying to get the carriage set so that its a flat rate of £3.50 if there is 1 or more items in the cart.
ANother issue with the same cart is that If you add something to the cart, then go to paypal to check out and then cancel to go back to the clients site, if you then click on clear cart it takes you through to paypal again. I have put a link in the PM to the cart in question. If you need any other info/access then please let me know
Cheers
Jamie
for the shipping use Number Of items > 0 for the trigger.
the trigger in your screen shot is Presence of Item with the ID 1 in the cart. That will only trigger if item ID 1 is in the cart.
use Number Of Items > 0 instead.
for the cancel issue, see PM
Jamie
thanks Jason, will try that.
re FTP see PM
I updated the checkout and confirm cart pages to fix the clear cart redirect issue.
Jamie
thanks Jason
you're welcome.
