Getting a java script error when inserting a text field from forms menu. When I tried any of the other types of fields, for example date, then it works fine. I have deleted the wincache file but no luck. Have had this problem several times and solved
Thread begun 6/06/2014 6:16 pm by rolf358571 | Last modified 6/09/2014 7:36 am by Jason Byrnes | 1681 views | 3 replies |
rolf358571
Getting a java script error when inserting a text field from forms menu. When I tried any of the other types of fields, for example date, then it works fine. I have deleted the wincache file but no luck. Have had this problem several times and solved it bu
This ongoing problem stops me in the tracks very often and I need to start over. I have tried earlier to also uninstall but did not work then so don't want to try again. Have deleted Wincache file 4 times now but no luck.
Need more details please.
What is the text of the error?
What Version of DW are you using?
What is your OS?
What extensions, including the version numbers are installed?
Please provide the steps you are following to produce the error.
rolf358571
Hi Jason.
Thanks for reply. I have answered next to your questions below.
First error dialog box just says: "The following Javascript error occured:" and no error showing.
Then the second dialog box says: "While executing object Tag in Text Field.htm, a Javascript error occured"
CS6
What is your OS?
Windows 7
DataBridge 1.1.3
Design extender 1.1.3
Ecart 5.0.7
I am using the insert menu/Form/Text to insert a text field in a form.
The same problem occurs if I try to insert a Text area or a Fieldset but not if I insert a Date or Color field.
Hope this will give you the correct information.
Kind regards
Rolf
There are newer versions of Data Bridge and Design Extender available.
You should uninstall Design Extender and Data bridge from the extension manager, then log into your account to download the most recent versions and install them
after installing to the extension manager, start DW to launch the WebAssist installer. If the WebAssist installer does not launch automatically, open a php page to force it to start. make sure to restart DW after the WebAssist installer completes.
NOTE:
The Insert -> Forms access point is a built in Dreamweaver function. That is not an access point that we added. if you continue to have a problem, you should contact Adobe for support
