How to print a training certificate
Thread begun 6/05/2014 3:35 pm by mora398588 | Last modified 6/10/2014 8:26 am by Jason Byrnes | 5046 views | 14 replies |
mora398588
I used DA to create a database and administrative site to track information and enrollments of our training attendees. So far, the database is working great. Now, I would like to take this project a step further - give our attendees the option to view and print their training certificate.
I understand that I will need create a user login so our attendees can sign in and view their courses, as well as view and print their training certificates. My dilemma is how do I come up or design a training certificate template where I can dynamically insert the attendee's name, course title, and course completion date.
I have already checked online for training certificate html or php templates and cannot seem to find any. I am uncertain what WebAssist can do for me. I am open to any suggestions, referrals to other sites, software, etc. to assist with this project.
Thank you for your time.
In this sense the training certificate would be a an HTML page that contains a recordset to pull in the dynamic data for the person viewing it.
use Dreamweaver to create the certificate design, and create the recordset that returns the dynamic data.
mora398588
Thank you so much for your suggestions. It did not occur to me to use Dreamweaver to design the certificate. Now I know what to do.
you're welcome.
mora398588
Things are working great with my training certificate. However, I would like to limit the attendee's access to the certificate based on their course status.
My database contains a column which records the enrollment status of an attendee, i.e., enrolled, cancelled, pending, complete, etc.. I would like only those attendees whose enrollment has a status of "complete" to view their training certificate.
I am thinking I could create a URL variable (Status) and use Security Assist to create a rule where the variable can return the certificate, such as ?Status=Complete. However, I am uncertain how to go about coding or creating the rule where the rule pulls the correct information from the correct database column (in this case, the Status column within the database).
Thank you for your time and assistance.
on the login page, edit the security assist authenticate user server behavior.
On the session tab, click the plus button and select the Status column to save the users status in a session at login.
Use that session when creating the access rule for the certificate.
mora398588
Thank you for your reply, Jason.
However, I was not very clear as to where the enrollment status was recorded. For that, I apologize. The enrollment status is recorded in another table (enrollments), and is not located in the contacts table where Security Assist will use to authenticate the user.
So, based on your suggestions, I am unable to add the "status" column as a session variable. Should I insert a recordset of the contacts table and INNER JOIN the enrollments table where the enrollment status column is located? Will SA be able to see the inner joined status column and thus create the session variable?
On the certificate page, create a recordset that looks up the status in the status table by the UserID session.
You can then use the set session value behavior to save the status to a session, and use the status session in the access.
when applying the access rule, just make sure that the code order has the page restriction code after the recordset and session code:
-recordset
-Set Session
-Page restriction
mora398588
Here is what I have done so far. I have attached my certificate file, as well as the rules page for your review. Any feedback?
Thank you.
The rs_enrollment recordset does not return the EnrollmentType column so will not be able to save that to the session.
