webassist/framework/checkout.php Not Found
Thread begun 6/05/2014 9:52 am by bill173836 | Last modified 6/06/2014 9:07 am by Jason Byrnes | 22955 views | 7 replies |
bill173836
On the checkout page I'm getting the following error. The requested URL /webassist/framework/checkout.php was not found on this server.
To the best of my knowledge I've never had a checkout.php page in the framework folder. This is particularly troublesome since the page is the checkout.php page. Any idea why I might be getting this error?
bill173836
http://www.funkymonkeycoupons.com
The form on the checkout page has been edited to 1) use recortdset info as the values, but the recordset is not returning a reszult, and 2) Submit on page load.
this is causing the validation on the confirm page to fail in an endless loop, becuase it redirects to checkout which submits on load, fails, redirects, submits, fails etc..
the recordset is set to filter using the UserID session variable, but your login creates a session named:
conID
use that session instead. and be careful when submitting a form on page load.
bill173836
Thanks, that seemed to fix it. I have a question on Captcha. I've added a Captcha to a form on this site and the captcha_Securtiy_Code & captcha_Securtiy_Answer sessions aren't showing up when I try to validate the form. Here is the register form page. Thanks again.
if the session are not showing in the bindings, you may have to create them
go to the bindings panel and click the plus button, select session and enter the session name.
if creating them is not sticking, use the OS file system browser to browse to the sites root, and delete the _notes folder.
bill173836
What do the session names need to be called. I tried captcha_Security_Code and captcha_Security_Code_1 the second one worked for the code but I also have the Answers on the page and I tried captcha_Security_Answer and captcha_Security_Answer_1 and neither worked.
for the security question, the session name is:
random_answer
