Universal Email behaviour - not updating when changes are made via the behaviour?
Thread begun 6/04/2014 7:46 am by Nathon Jones Web Design | Last modified 6/05/2014 8:48 am by Jason Byrnes | 2459 views | 3 replies |
Arrgh. This was working, we haven't done ANYTHING to it (because we're scared out of our wits of further bugs and glitches), and sure enough it's no longer working! :o(
In the Universal Email behaviour on our confirm.php page, we have an e-mail address in the Bcc field. We remove that, and save the page, but when we open it again the e-mail address is back in the Bcc field.
The e-mails are no longer sending either, upon successful payment. What is all this about?
I've attached confirm.php. Hope you can help.
Thank you.
NJ
waue_confirm_1.php just doesn't update when you make changes via the server behaviour panel, so how can we be sure that ANY changes we've made in there have ever worked?
make sure that the webassist/email/waue_confirm_1.php page is not set to be read only, if that file has become read only, it will not allow for changes to be written to it.
I see a problem in the to address at line 510:
$RecipArray[$CurIndex ][] = "".(WA_getSavedFormValue("","First_Name"))  ."|WA|".(WA_getSavedFormValue("","Email_Address"))  ."";
that code should be:
$RecipArray[$CurIndex ][] = "".(WA_getSavedFormValue("CheckoutWizard_Sharp_Default","First_Name"))  ."|WA|".(WA_getSavedFormValue("CheckoutWizard_Sharp_Default","Email_Address"))  ."";
I have tried to reproduce that code error by making an edit to the server behavior, but cannot.
waue_confirm_1.php is not read only. The server behaviour simply isn't removing the Bcc address from the waue_confirm_1.php file. So how do we do that manually if the extension isn't working correctly, as it appears that is our only option? Here's the line in the waue_confirm_1.php file:
//BCC Entries
$WA_MailObject = WAUE_AddBCC($WA_MailObject,"sales@ledwarehouseuk.com");
Regarding the address at line 510 - you'd previously helped us with that, if you recall, because I'd reported that it was arriving with a blank From value. I'm not sure why that's no longer working but the new changes you've recommended above have resolved the issue and I've learnt that it's best not to ask why.
Thank you.
NJ
simple remove this line completely to remove the bcc address:
