The setup wizard for PowerCMS stops & shows a blamk page on /install_cms/database.php
Thread begun 6/03/2014 9:57 am by lennon59 | Last modified 6/03/2014 12:18 pm by Jason Byrnes | 3060 views | 7 replies |
lennon59
http://dreaminonmainstreet.com/install_cms/database.php
a blank page means that a php error is occurring but error reporting is turned off.
to turn error reporting on, add the following code at line 1:
error_reporting(E_ALL);
once we know what the error is, we will be able to troubleshoot the cause.
lennon59
I put error reporting code at the top, and . .
No Effect. Code snippet in private message
lennon59
Here's the info
Here you go
the templates/install.dwt.php and admin.dwt.php files on the server had become corrupted.
I fixed the problem by uploading new copies of those files.
lennon59
Solved! Thanks!
Thank you
you're welcome.
