changing order of images
Thread begun 6/02/2014 10:48 am by Sally | Last modified 7/18/2014 7:11 am by Jason Byrnes | 5281 views | 15 replies |
Sally
I added an image to a gallery and it's now the last image. I dragged it to be the first image, but the number by the thumbnail still indicates it's the last and that's where it shows. I don't see any place I can "save" this new order. How do I get it to save the new order? Thanks.
Sally
See pm
See PM
Sally
see pm
see PM
info72555
I seem to have the same issue - not being able to change the order of photos in the gallery
Hi Jason, I am using a layout for your galleries that does not seem to like rearranging of images because the changes get reverted right away and I am unable to change the order of the photos. Would you please share your fix so I can try it on my end?
attached is an updated copy of the admin_gallery/js/manageimages.js file that should fix the problem.
info72555
When I log in to PG the directory is "admin"... :-(
Will the file you sent work in this folder as well?
Thank you Jason,
Tim
it should, yes,
