Passwoooooord request loop install live site\
Thread begun 6/02/2014 9:43 am by software.current355386 | Last modified 6/04/2014 7:47 am by Jason Byrnes | 2589 views | 5 replies |
installed cms locally , within my xampp setup, this took some time, everthing appeaered to work, error reported within framework, looked in forum found new version, installed, errors went and all worked as expected.
scynced wth live site, tried toaccess the admin (admin_CMS), automaticall start a 5step nstall, got to stp4 and typng not my strongpoint du to having parkinsons.triedtypi, cut+paste .................. get error ERROR: Failed to save the settings in the database. Please verify your database connection.
stuck, no cancel option,what do i doto resolve issue..
The install process would have started because not all of the files where uploaded to the server.
when uploading to the live site from local:
-edit the files in the Connections folder to use the correct info for connecting to the remote database.
-Upload all site files including the installed.txt file in the connections folder to the server.
-export the database from the local server and import it to the remote server.
this page has details on exporting and importing databases using phpMyAdmin.
http://www.techrepublic.com/blog/smb-technologist/import-and-export-databases-using-phpmyadmin/
dw no files to sync , still sameaftr copng DAtabe and tables over
connection file looks ok
will look a doin a COMPLETE upload again of all file
Since you already did the install on local host, it should not try to do the install again.
the install is triggered if the /Conenctions/installed.txt file is not uploaded to the server,
make sure to upload all the files in the connections folder to the server.
txt file ddnt uploaddueto cloaking,xenow wrks
notice two issues\\\\\\\
1. no way fidentifng sysem beng accessed ieee diff themeordisply naaamr onscreen
2 USIGG temp subdomain,WEN IS RENAAAMED tlive will tht bea problem
I dont understand the question. Please provide additional details.
