Sending email based on product bought
Thread begun 6/02/2014 5:34 am by The Flying Fox | Last modified 6/02/2014 12:28 pm by Jason Byrnes | 3201 views | 7 replies |
The Flying Fox
Hi
I have modified code to send an email specific to the category of the item purchased.
at the moment is have just set up 3 categories and change the code in the UE code from
$EmailRef = "waue_checkout_success_1";
To
if ($CHG_cart->DisplayInfo("category") == 1) {
} else
if ($CHG_cart->DisplayInfo("category") == 2) {
$EmailRef = "waue_checkout_success_2";
} else
if ($CHG_cart->DisplayInfo("category") == 3) {
$EmailRef = "waue_checkout_success_3";
but this is sending 3 email instead of just one based on the category purchased.
Is this possible or am I just running round in circles?
Andy
You would need to set up a universal email instance for each of the 3 categories.
then add the if statement around the entire instance, not just the email reference name.
The Flying Fox
Hi Jason,
I take it you mean this instance?
if (("" == "")) {
//WA Universal Email object="mail"
@session_write_close();
set_time_limit(0);
$BurstSize = 200;
$BurstTime = 1;
$WaitTime = 1;
$GoToPage = "";
$RecipArray = array();
$StartBurst = time();
$LoopCount = 0;
$TotalEmails = 0;
$RecipIndex = 0;
// build up recipients array
$CurIndex = sizeof($RecipArray);
$RecipArray[$CurIndex] = array();
$RecipArray[$CurIndex ][] = "".(WA_getSavedFormValue("CheckoutWizard_NewFromBlank_Default","Email_Address")) ."";
$TotalEmails += sizeof($RecipArray[$CurIndex]);
$RealWait = ($WaitTime<0.25)?0.25:($WaitTime+0.1);
$TimeTracker = Array();
$TotalBursts = floor($TotalEmails/$BurstSize);
$AfterBursts = $TotalEmails % $BurstSize;
$TimeRemaining = ($TotalBursts * $BurstTime) + ($AfterBursts*$RealWait);
if ($TimeRemaining < ($TotalEmails*$RealWait) ) {
$TimeRemaining = $TotalEmails*$RealWait;
writeUEProgress($EmailRef,0,$TotalEmails,$TimeRemaining);
while ($RecipIndex < sizeof($RecipArray)) {
$EnteredValue = is_string($RecipArray[$RecipIndex][0]);
$CurIndex = 0;
while (($EnteredValue && $CurIndex < sizeof($RecipArray[$RecipIndex])) || (!$EnteredValue && $RecipArray[$RecipIndex][0])) {
$starttime = microtime_float();
if ($EnteredValue) {
$RecipientEmail = $RecipArray[$RecipIndex][$CurIndex];
} else {
$RecipientEmail = $RecipArray[$RecipIndex][0][$RecipArray[$RecipIndex][2]];
$EmailsRemaining = ($TotalEmails- $LoopCount);
$BurstsRemaining = ceil(($EmailsRemaining-$AfterBursts)/$BurstSize);
$IntoBurst = ($EmailsRemaining-$AfterBursts) % $BurstSize;
if ($AfterBursts<$EmailsRemaining) $IntoBurst = 0;
$TimeRemaining = ($BurstsRemaining * $BurstTime * 60) + ((($AfterBursts<$EmailsRemaining)?$AfterBursts:$EmailsRemaining)*$RealWait) - (($AfterBursts>$EmailsRemaining)?0:($IntoBurst*$RealWait));
if ($TimeRemaining < ($EmailsRemaining*$RealWait) ) {
$TimeRemaining = $EmailsRemaining*$RealWait;
$CurIndex ++;
$LoopCount ++;
writeUEProgress($EmailRef,$LoopCount,$TotalEmails,round($TimeRemaining));
wa_sleep($WaitTime);
include("../../webassist/email/waue_checkout_success_1.php");
$endtime = microtime_float();
$TimeTracker[] =$endtime - $starttime;
$RealWait = array_sum($TimeTracker)/sizeof($TimeTracker);
if ($LoopCount % $BurstSize == 0 && $CurIndex < sizeof($RecipArray[$RecipIndex])) {
$TimePassed = (time() - $StartBurst);
if ($TimePassed < ($BurstTime*60)) {
$WaitBurst = ($BurstTime*60) -$TimePassed;
wa_sleep($WaitBurst);
else {
$TimeRemaining = ($TotalEmails- $LoopCount)*$RealWait;
if (!$EnteredValue) {
$RecipArray[$RecipIndex][0] = mysql_fetch_assoc($RecipArray[$RecipIndex][1]);
$RecipIndex ++;
@session_start();
$_SESSION[$EmailRef."_Status"] = $GLOBALS[$EmailRef."_Status"];
$_SESSION[$EmailRef."_Index"] = $GLOBALS[$EmailRef."_Index"];
$_SESSION[$EmailRef."_From"] = $GLOBALS[$EmailRef."_From"];
$_SESSION[$EmailRef."_To"] = $GLOBALS[$EmailRef."_To"];
$_SESSION[$EmailRef."_Subject"] = $GLOBALS[$EmailRef."_Subject"];
$_SESSION[$EmailRef."_Body"] = $GLOBALS[$EmailRef."_Body"];
$_SESSION[$EmailRef."_Header"] = $GLOBALS[$EmailRef."_Header"];
$_SESSION[$EmailRef."_Log"] = $GLOBALS[$EmailRef."_Log"];
if (function_exists("rel2abs")) $GoToPage = $GoToPage?rel2abs($GoToPage,dirname(__FILE__)):"";
if ($GoToPage!="") {
header("Location: ".$GoToPage);
would I just copy the code or create it from scratch
Andy
Yes, that is the code block for a UE server behavior.
dont copy it, create the other 2 instances of the server behavior.
Webassist -> Create Email Message
to create the emails for each category, then add the if statement around the UE server behaviors so the correct one triggers depending on the category.
If you need further assistance with this, I Would suggest signing up for a premiere support appointment:
http://www.webassist.com/premier_request.php
The Flying Fox
Hi Jason
I think i've got this one sorted just a quick one with the category
as my category is a numeric value for the index would I surround the 1 in quotes or leave as it is here?
Andy
use quotes
The Flying Fox
Thank you I wasn't too sure but I did think that I should.
Better to check though
Andy
you're welcome.
