Restoring Data Bridge 1.1.9 presets
Thread begun 5/30/2014 10:56 pm by thompson.lewis308225 | Last modified 4/27/2015 2:10 pm by Ray Borduin | 3832 views | 5 replies |
Where can i find the presets for Data Bridge 1.1.9 ? I would like to be able to restore them to the defaults. I was only able to find sources for installing older versions of Data Bridge components.
To restore the default presets, you would need to uninstall Data Bridge, then install it again.
I have used extension manager to remove Data Assist and Data Assist Extender. Everything looks like it has uninstalled properly. However, when i reinstall the extension the presets that i originally created show back up. I also notice that when i go to the Configuration directory there seems to be remnants of these 2 extensions. How do i completely delete the presets i created.
you can either:
1) open the preset manager and export all presets, then uninstall the extensions and reinstall them to restore the presets
or
2) recreate the users configuration folder as outlined in step 12 of the Adobe troubleshooting guide:
http://helpx.adobe.com/dreamweaver/kb/troubleshoot-javascript-errors-dreamweaver-cs4.html#main_user_config
then reinstall the extensions
ks356867
Data Bridge v1.2.2 > Security Assist > Need to recover Presets
I own Data Bridge 1.2.2, and have a similar problem with Security Assist. In the Preset Manager, I have removed all of the presets for both Security Assist and Data Assist, and uninstalled/reinstalled Data Bridge. Both Preset Manager lists are still empty. I don't feel confident enough to mess with my registry outlined in the Adobe troubleshooting guide, and I'm using CS6 that is not covered by the guide.
Thanks,
Ken
Did you save a copy of your presets as you removed them? Did you save a copy of your old user configuration folder?
You can export and then re-import your presets.
