"Click here to verify your email address" link inserts newsletter subscriber once, but emails coupon code over and over
Thread begun 5/28/2014 4:40 pm by graham | Last modified 5/30/2014 1:47 pm by Jason Byrnes | 6092 views | 11 replies |
graham
Jason, awhile back, Ray helped me, through a couple of premier support sessions, to double opt-in my newsletter subscribers, while sending out a random generated coupon code when successful. The problem is that when a subscriber clicks the "click here to verify your email address" link they are entered into my database once, but, if they continue to click the original "verify" link, Ray's code keeps sending unique codes ... I want to make sure that if someone clicks it again, they don't get additional codes. I have attached the files that prompt the function ... can you help?
add an additional if statement around the UE code block:
<?php if($row_reNVerify['emailVerified'] == "0") { ?>
< UE code Block >
<?php } ?>
graham
So that the email only sends for a new registrant - perfect. But I think the coding on the newsletter_user_confirm page will still create and insert additional records in my database for each click of the email link sent, even if universal email does not initiate ... how can I tell the page to only insert the registrant, and the accompanying coupon code, once? I still have individual emailid with 4 and 5 codes in my database from multiple clicks of the verification link. Thanks, Jason.
add the same if statemet around the update record code that adds the additional coupons so it only happens once.
graham
I applied your instructions to the UE block, and it worked as desired - no additional emails are sent. However, I have not had any luck in stopping he original verification link from creating additional discount codes. I am not sure whether to add the if statement around the insert record to usercoupons, or one of the update record to newsletter blocks. When the subscriber clicks on the original email verification link, and they have already clicked it once, can I create a show if area on the newsletter_confirm_page that tells them they have already verified the link? What would be the condition to hide the original "Thank you for ..." message? Thanks for any additional help you can give, Jason.
This is the code that inserts the coupn codes:
// WA DataAssist Insert
if ("" == "") // Trigger
$WA_connection = $mysql_purple;
$WA_table = "usercoupons";
$WA_sessionName = "id";
$WA_redirectURL = "";
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = false;
$WA_fieldNamesStr = "emailid|couponCode|couponAmount";
$WA_fieldValuesStr = "".$row_reNVerify['emailid'] ."" . $WA_AB_Split . "".$_SESSION['CouponCode'] ."" . $WA_AB_Split . "0.2";
$WA_columnTypesStr = "none,none,NULL|',none,''|none,none,NULL";
$WA_fieldValues = explode($WA_AB_Split, $WA_fieldValuesStr);
$WA_connectionDB = $database_mysql_purple;
@session_start();
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id($WA_connection);
if ($WA_redirectURL != "") {
$WA_redirectURL = str_replace("[Insert_ID]",$_SESSION[$WA_sessionName],$WA_redirectURL);
place the if statement around that code.
graham
Lightning response ... wow - thank you. I implemented the code and the outcome is almost perfect. No additional UE - no duplicate entries for the same emailID, but the page coding still creates a new random code and replaces it in usercoupons over the one that was originally distributed to the subscriber and, with no UE generated, they will be trying to apply a non-existent one. Best way to not produce the second (or, more) code at all? Again, thanks for the help.
i see no code on your page that would replace the coupon in the usercoupons table.
i only see code on the page to write the user coupon session:
<p>As a <strong>special thank you for registering</strong>,<br/>here is your <strong>20% Off Coupon Code</strong>:<span style="color:#609
"> <?php echo $_SESSION['CouponCode']; ?></span><br/>The code <strong>may be used only once</strong> and will<br/>
"><strong>deduct 20% from your order total</strong></span>.<br/>
you could add the same if statement around that code to not display the coupon once they have already verified.
graham
Even if I blank it out on the page, the $_SESSION["CouponCode"] is still produced at the top on page load, which, at some point, inserts and overwrites any previously entered code in the usercoupons. Is there a condition to be added at the top that prevents $_SESSION["CouponCode"] from setting if the email address is already present?
move the code to set the session:
if("" == "") {
$_SESSION["CouponCode"] = "".WA_RandomPassword(6, false, true, true, "") ."";
to be after the code for the recordset, than use the same if state around it to check if email verified in the recordset is equal to 0
