Displaying date as dd-mm-yyyy and inserting to MySQL DATETIME field?
Thread begun 5/27/2014 11:34 am by Nathon Jones Web Design | Last modified 12/28/2015 9:02 pm by Ray Borduin | 30374 views | 9 replies |
I've been using this:
<?php echo date("Y-m-d H:i:s"); ?>
...to put the date into a hidden field on my insert and update forms. How, though, can I take an existing date from a DATETIME field, display it in dd-mm-yyyy H:i format, so the UK user and understand it and easily edit it, AND ensure that when the user then tries to UPDATE that field that it will save back in the database in the correct MySQL default date format?
Thank you
NJ
to display a recordset field on the page, you would code similar to:
<?php echo($row_recordsetName['ColumnName']); ?>
if that field is a date filed, you can form it using the date function:
<?php echo(date("m-d-Y", strtotime($row_recordsetName['ColumnName']))); ?>
CraigRBeta Tester
The date is always stored in your table in the format YYYY-MM-DD.
You can manipulate how this appears on screen just by formatting it according to the php date format function
eg echo date('l F j, Y', strtotime($row_recordset['MyDate']));
http://www.w3schools.com/php/func_date_date.asp
Regardless how it is formatted, it needs to be saved back into the database table in the YYYY-MM-DD format.
To do this, I pass the date field value into a function to set the appropriate date format.
eg if I am using the datepicker tool, the date is displayed on screen as dd/mm/yyyy (We in the UK like it the proper way round)
when saved back into the database table, I pass the field value through a function
function formatUKDateMySQL($date) {
$d = str_replace(" ","",$date);
$d = explode('/', $date);
$d = $d[2].'-'.$d[1].'-'.$d[0];
return $d;
so the dataassist insert behavior includes a line like this...
"".((isset($_POST["MyDate"]) && $_POST["MyDate"]!="" )?formatUKDateMySQL($_POST["MyDate"]):"")  .""
I'm not familiar with functions, although I'm increasingly aware of how useful they are. Where does the function code sit on the page?
I've got a nice date display by using this:
<?php echo date('jS F Y h:i A', strtotime($row_rsEDITSTOCK['LEDProductUpdateDate'])); ?>
I've also got an form field (LEDProductUpdateDate), which is what saves to database, which displays the current date/time like so:
You mention passing that field value into the function. Is that done on submit of the UPDATE form?
My DataAssist Update form has this line:
$WA_fieldValuesStr = "".((isset($_POST["LEDstock"]))?$_POST["LEDstock"]:"") ."" . $WA_AB_Split . "".((isset($_POST["LEDProductUpdateDate"]))?$_POST["LEDProductUpdateDate"]:"") ."";
I'm not sure what I need to change in both the form field and UPDATE code, if you wouldn't mind helping out?
Thank you
NJ
where the form field LEDProductUpdateDate already uses the Y-m-d format that the database requires, you do not need to use any additional formatting funcitons
formatting functions would only be \needed if the form element used a different format.
the function would need to be defined before the update record code, the used in the update record code like this:
$WA_fieldValuesStr = "".((isset($_POST["LEDstock"]))?$_POST["LEDstock"]:"") ."" . $WA_AB_Split . "".((isset($_POST["LEDProductUpdateDate"]))?formatUKDateMySQL($_POST["LEDProductUpdateDate"]):"") ."";
Yes, sorry, Y-m-d is the correct format for the database but when my client goes to edit it they're bound to type in d-m-Y or, rather, dd-mm-yyyy which, on submission to database, will cause problems.
What I don't understand about the function CraigR has provided an example of is where in that function it picks up the form field, in my case "LEDProductUpdateDate"?
Should I be replacing "$date" with the name of my form field? So instead of this....
return $d;
...it becomes this:
function formatUKDateMySQL($_GET['LEDProductUpdateDate']) {
$d = str_replace(" ","",$_GET['LEDProductUpdateDate']);
$d = explode('/', $_GET['LEDProductUpdateDate']);
return $d;
Also, thinking about this, I'm concerned about what happens if my client lazily types something like 21-1-14 when entering a date.
I'd use a datepicker tool, but I want a default value of "today" in the date field.
As ever, I appreciate your advice and guidance. Thank you.
NJ
CraigRBeta Tester
I would urge you to use the datepicker tool, it is easy to configure and looks nice
- also there are lots of options you can set, like limiting the date range etc, so you should be able set it to default to the current date easily enough.
http://api.jqueryui.com/datepicker/
Re the function, you don't need to change anything
all you need to do is call the function, putting in your date field as a parameter.
the function in question expects an input date in the format dd/mm/yyyy and will produce a date in the format yyyy-mm-dd
so all you need to do is change the line in the update query like so
"".((isset($_POST["LEDProductUpdateDate"]))?$_POST["LEDProductUpdateDate"]:"").""
to
"".((isset($_POST["LEDProductUpdateDate"]))?formatUKDateMySQL($_POST["LEDProductUpdateDate"]):"").""
If your date format in the field is different to dd/mm/yyyy then you will need to change the function which manipulates the string accordingly, whatever the start point is, the result should be in the format yyyy-mm-dd
Hope that helps
DarylBeta Tester
Hi CraigR
How would you do this for a datetime field?
Many Thanks
CraigRBeta Tester
There is a useful addon to the datepicker tool which can add the time to your selected date
http://trentrichardson.com/examples/timepicker/
You can extend the capability of the function above to reformat the time element of the field as well
Puguh
<?php echo(date("m-d-Y"strtotime($row_recordsetName['Column']))); ?>
