DataBridge still relies on Dreamweaver's outdated server behaviors and MySQL connection scripts?
Thread begun 5/26/2014 8:34 am by randyrie405335 | Last modified 6/16/2014 11:16 am by Jason Byrnes | 7990 views | 11 replies |
randyrie405335
I see that DataBridge still relies on Dreamweaver's server behaviors which are being deprecated in CC along with PHP's mysql_connect() function - replaced with mysqli or PDO. Will you be soon updating Databridge with its own database connection script that uses mysqli or PDO? And, are you planning on developing your own server 'behaviors' to replace the existing behaviors no longer supported by Adobe?
We are currently working on a MySQLi extensions that will create versions of the standard DW server behaviors using MySQLi. after that is released, we will be upgrading Data Bridge to use MySQLi as well.
randyrie405335
Update... I just downloaded and am learning to use your MySQLi extension. I notice, however, that DataBridge's Data Assist still requires the use of deprecated DW recordset behaviors rather than MySQLi recordsets. When will DataBridge be upgraded to use MySQLi?
randyrie405335
Also, I'm a bit disappointed your recordset builder does not allow the testing of a complex query - thought for sure you would improve this old Dreamweaver flaw.
codamedia
This post has been deleted.
Data Bridge and Design Extender Still use the older MySQL libraries.
The MySQLi Extension is the groundwork that was needed to be laid for starting the MySQLi migration.
Now that the MySQLi extension is released, we be starting to work on migrating Data Bridge, Design Extender and eCart.
Data Bridge is the first one we start on, as it is the most database driven of the extensions, it will take the most time to complete
iainmacdonald331081
Thanks Jason - I was just going to post a similar question.
As far as I can tell during this transition period there are two option:
1. Use DataBridge to create insert / update pages that will create the required forms, but won't include the new mySQLi libraries.
2. Use the mySQLi server behaviours on pages where any forms are already added, either handcuffed or presumably using form builder, to insert / update using the mySQLi libraries.
And that when Databridge is updated, we'll be able to use DataBridge to create the insert / update pages that will include the mySQLi libraries?
The available options really depend on your servers capabilities. If your host still supports the MySQL libraries you can continue using Data Bridge as is.
If your host has started an Early adoption of not allowing MySQL, then you will need to create form manually (or with form builder) and use the MySQLi extensions to build the insert / update functionality.
iainmacdonald331081
Hi Jason - I just meant the options with the DataBridge / MySQLi extensions as they currently are, rather than regards hosting support.
I guess I was trying to figure out a current workflow - when I saw the MySQLi extension, and the option to use that to create an Insert record, I guess I thought that was equivalent to the DataBridge > DataAssist Pages functionality. But it only creates the insert code, rather than the code for the form also.
So as it is currently they both do different, but overlapping parts of the job.
If I was a complete newcomer I would ask what the difference is between using:
WebAssist > Database > DataAssist Pages
and
Server Behaviours > WebAssist > MySQLi > Data Management > MySQLi Insert Record
to insert a new record?
And when it would be appropriate to use each in terms of workflow.
Think of it this way Ian:
In Dreamweaver, without having any webassist extensions installed, there are behaviors for insert, update. delete, user authentication, etc.
These are fairly simplistic server behaviors that where developed by Macromedia in the Dreamweaver Ultra-Dev days. And it was these server behaviors that where the groundwork for the behaviors we created in Data Assist / Security Assist and the other extensions.
The MySQLi server behaviors extension recreates those groundwork server behaviors using the MySQLi library and is the groundwork we will be able to use to migrate Data Bridge and the other extensions to using the MySQLi library.
There where many limitations to those earlier server behaviors, for example; the insert would only support form data. On recreating them, we have made them a bit more flexible.
For now, Data Bridge and the other extensions will still use MySQL. If you find yourself in a server environment that no longer supports the MySQL library, you can use the MySQLi server behaviors to create pages that will work in that server environment.
It doesn't contain the page creating wizards that are in Data Bridge, but does give the basic functionality that Adobe have removed by deprecating the server behaviors.
