Data Assist Update with AES_ENCRYPT?
Thread begun 5/24/2014 2:37 pm by carl181913 | Last modified 2/11/2015 5:48 pm by stephen287384 | 7899 views | 10 replies |
carl181913
Data Assist update record with AES_ENCRYPT?
I am trying to add AES_ENCRYPT to the "busNum" field in the snippet of code below generated by Data Assist update record:
$WA_fieldNamesStr = "cartoff|busCardName|busCard|busNum|busXmon|busXyear|busCode|busCardReset|payUpdate";
$WA_fieldValuesStr = "" . "|" . "".((isset($_POST["busCardName"]))?$_POST["busCardName"]:"") ."" . "|" . "".((isset($_POST["busCard"]))?$_POST["busCard"]:"") ."" . "|" . "".((isset($_POST["busNum"]))?$_POST["busNum"]:"") ."" . "|" . "".((isset($_POST["busXmon"]))?$_POST["busXmon"]:"") ."" . "|" . "".((isset($_POST["busXyear"]))?$_POST["busXyear"]:"") ."" . "|" . "" . "|" . "" . "|" . "";
$WA_columnTypesStr = "',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''";
$WA_comparisonStr = "=|=|=|=|=|=|=|=|=";
I saw a previous post that said to try the following but it returns an error so the syntax must be wrong:
((isset($_POST["busNum"]))?AES_ENCRYPT($_POST["busNum"], 'encryptkey'):"")
I am using PHP & MySQL
Any help would be GREAT!
not necessarily. The syntax looks OK to me, what did the error say exactly?
carl181913
I am not seeing a specific error just the page will not load and it fails to update the record. If I remove the code and put it back to ((isset($_POST["busNum"]))?$_POST["busNum"]:"") the page loads fine and the record updates just not encrypted.
Here is what the code looks like when I add the AES_ENCRYPT:
$WA_fieldValuesStr = "" . "|" . "".((isset($_POST["busCardName"]))?$_POST["busCardName"]:"") ."" . "|" . "".((isset($_POST["busCard"]))?$_POST["busCard"]:"") ."" . "|" . "".((isset($_POST["busNum"]))?AES_ENCRYPT($_POST["busNum"], 'encryptkey'):"") ."" . "|" . "".((isset($_POST["busXmon"]))?$_POST["busXmon"]:"") ."" . "|" . "".((isset($_POST["busXyear"]))?$_POST["busXyear"]:"") ."" . "|" . "" . "|" . "" . "|" . "";
carl181913
here you go...
you are confusing MySQL funcitons and PHP functions.
AES_ENCRYPT() is a MySQL function, not a PHP funciton.
in php you can use mcrypt_encrypt and use the RIJNDAL encryption method which is AES compliant, but PHP does not have a AES_ENCRYPT() funciton
http://us2.php.net/manual/en/function.mcrypt-encrypt.php
carl181913
Ok, I see what you mean now. I took a look at the php mcrypt_encrypt function but still having an issue with how to implement in the data assist code. Do you have any code examples of how to do this?
In the Data Bridge insert record behavior, when you select a binding, change the format list to use RIJNDAL Encryption.
carl181913
I don't have data bridge just Data Assist. Is there any way to modify the the Data Assist code to use AES_ENCRYPT function when saving to MySQL? The reason I ask is because I was able to get the RIJNDAL Encryption to work but the problem is that the data is already encrypted using AES and I can't get RIJNDAL Encryption to encrypt/decrypt in the same way.
Encryption is a part of Security Assist.
to use it Data Assist without having security assist would require unsupported custom coding.
