Image re-sizer's dynamic folder creation...
Thread began 5/24/2014 11:37 am by asarcona308398 | Last modified 9/28/2014 6:55 am by asarcona308398 | 753 views | 2 replies |
asarcona308398
Hey Guys the folder creation system in Image re-sizer needs some refinement....
The location of the folders automatically generated by image re-sizer makes the site extremely cluttered, and puts them in a lot of different places when you use the extension many times in a site... a simple dialog box with directory placement would be ideal, so the images could be managed easier, or simply create a "common directory" that image re-sizer will always find and use.
The reason I suggest this is that if you happen to be using image re-sizer for dynamically generated things, the folders and images remain in directories that don't need to remain on the server... to be able to set a script to remove these files similar to removing session files on the server becomes very difficult to maintain.
Jamie
I use a cron job and a delete script to empty the image_cache folder every day. I can specify a specific folder within the image_cache folder if I choose.
If you're not familiar with this would be happy too send it to you?
All the best
Jamie
asarcona308398
Hey Jaime...
I just came upon this again and I have a customer with many gigs of stale pics bogging down his server....
Please send me your solution... it seems to be the best suggestion if come across!
Thanks,
Tony
