Price Not Being Passed Correctly To Shopping Cart.
Thread begun 5/23/2014 12:05 pm by bill173836 | Last modified 6/05/2014 8:38 am by Jason Byrnes | 7660 views | 25 replies |
bill173836
Jason,
I started a new thread as the last one was getting so long. I figured out the updating data and the product-details.php page now goes to the shopping-cart.php page. But it's not passing the correct price. Here are the product-details.php and shopping-cart.php pages for your review. Thanks in advance.
You can find the pages at https://www.familyfriendlystore.com/products-detail.php?ProductID=1000 to see how it works and that when you add it to the cart the price isn't being reflected correctly on the shopping cart.
price looks correct for me.
bill173836
If you choose one of the options listed. The price changes. So when you press the add to cart button it's not sending the proper charge Try this link https://www.familyfriendlystore.com/products-detail.php?ProductID=1000&skucolor=4&skusize=7&skuudo1=15 the charge should be $0.04 but only $0.03 is being passed.
And if you choose this one https://www.familyfriendlystore.com/products-detail.php?ProductID=1000&skucolor=5&skusize=7&skuudo1=15 which should be $0.05 it's only sending $0.02.
That was not clear from the initial question.
to troubleshoot, create a new blank php page and add a cart display to it. In the display settings set it to show all columns.
send a copy of the cart object file and a link to that page.
bill173836
https://www.familyfriendlystore.com/blank.php
so looking at the cart display, nothing is going into the price increment columns.
this leads me to question the recordsets for looking up the price increment values.
on this page:
the select list that seams to be changing the price is the version, on looking at the source code the code for that select list is:
<select name="skuudo1" class="MenuList" id="skuudo1" onchange="this.form.submit()">
<option value="15" selected="selected">Hardcover</option>
<option value="17">Soft Cover</option>
</select>
so that means the select list name is:
skuudo1
however, in the udo1Lookup recordset, you are using the form element name:
siteCart_1_UDO1_Add
which does not match what is being used in the form.
bill173836
I got the previous problem to work but I've run into an issue on the shopping cart that is blowing my mind. What is happening is that if I create a session variable to display the color, size, etc when I create an if else statement the variable is recognized as 0. Which makes the if else statement not work properly. It should display Color: Green etc. Only if there is a value that is not 0 or empty. I'm sending the shopping cart page the code in question starts at line 298.
You can add an item to the shopping cart to see it run.
https://www.familyfriendlystore.com/products-detail.php?ProductID=1000&skucolor=5&skusize=7&skuudo1=9
Thanks.
this:
$SKU == '' OR $SKU == '0'
is not valid syntax for an OR comparison. val;id syntax would be:
$SKU == '' || $SKU == '0'
bill173836
That didn't work either. In the if statement the session is always being defined as 0 yet if you echo it somewhere else it will show either a blank space or the assigned value.
In reality, this is custom coding i wont be able to help with much, You should sign up for a premiere support appointment to get help with this:
http://www.webassist.com/premier_request.php
