Download file setup
Thread begun 5/23/2014 5:22 am by s.joiner74419001 | Last modified 4/28/2015 11:53 am by Ray Borduin | 6707 views | 19 replies |
s.joiner74419001
Download file setup
I have a 'Download file' behaviour applied to a form action page with a trigger of "before page load" so when the form is submitted it re-directs to the action page and downloads the PDF file. This works fine on desktop but on mobile devices it displays the download as the web page.
Is there a workaround for this?
I case there isn't I have tried to add a Submit button on its own on the page with the download behaviour applied to it but as explained in the Tutorial, you don't get an ID field to enter 'download' in it and there is no Submit/Button Download Pressed trigger option.
Does the button need to be in a form? All I want is a button the user clicks to download a PDF?
The download may not work on mobile browsers. I know most mobile browsers don't properly implement file fields, so file upload does not work on mobile.
To use a button submit to submit a form, yes, the button will need to be in the form.
your form should also contain a hidden element that sets the download file name.
s.joiner74419001
Problems again with file download
I am struggling to set up a download file form again and just can't seem to figure out where I am going wrong.
Here's the form.
<form method="post" enctype="multipart/form-data" name="download-file" id="download-file" action="" >
<input type="hidden" value="<?php echo $row_rsEnqDetails['files_c']; ?>">
<button type="submit" id="download" name="download" class="btn btn-default btn-xs">Download</button>
</form>
I have attached the full page if someone could help.
Thanks in advance!
Your hidden form element doesn't have a name... seems like you are trying to use it to pass the file name to be downloaded.
Also your download file name is set to: $_SESSION['members_id']
Seems like that would be set to the posted hidden form name since the file name isn't stored in that session variable.
I'd probably add: name="downloadFile"
to your hidden form element and then update the file name in the download server behavior to: <?php echo($_POST['downloadFile']); ?>
s.joiner74419001
I'm totally confused now. I tried what you suggested but still know success. I think we need to go back to basics.
Files are uploaded by our members to a folder on our server where the membership number is passed to the file name. So for example Jo Bloggs with a memb' number 100001 uploads a file. This file is then named 100001.pdf. The folder it is placed in is admin/file-uploads/.
So I want to be able to download this file.
my download server behaviour is set to:
WA_DFP_SetupDownloadStatusStruct("WA_DownloadResult1");
if(isset($_POST["download"]) || isset($_POST["download_x"])){
WA_DFP_DownloadFile("WA_DownloadResult1", "../admin/file-uploads/", "100001_1.pdf", "[FileName]", false, false, false, "", "", "", "");
My form is here:
<input type="hidden" name="downloadFile" value="">
</form>
I expect the hidden field needs a value but I am not sure what.
Attached is a screen shot of what I get when I click the button.
Where am I going wrong?
s.joiner74419001
Hi Ray.
I've tried the same setup on a new page and it worked so there is something effecting it on the page.
Any ideas? .. page attached.
Cheers!
s.joiner74419001
Question. Can you have an upload behaviour and a Download behaviour on the same page. Because I removed the upload behaviour from the page and then the download worked. Why is this?
s.joiner74419001
All sorted now! not sure what the issue was but I re-worked the page and it now works.
s.joiner74419001
So I have been working on another page that also has download behaviours which I have finished and is all working correctly. I then go back to the previous page I had problems with but eventually got working and the problem is back. I have not altered the page since so how can this happen?
Is there external PHP files that are possibly used by both pages that could be altered when editing one page which would effect the other?
Attached is the faulty page whith two download behaviours. both give the result similar to post #5 in the browser
There is a shared library file, but it wouldn't change from page to page, so one breaking the other doesn't make sense. I'd like to debug this with you directly. Please post a url to both pages and FTP access to the private area and I'll debug and let you know what is going on.
