Wampserver & Webassist problems
Thread begun 5/22/2014 8:36 am by Dennis | Last modified 5/22/2014 10:04 am by Jason Byrnes | 3177 views | 7 replies |
Dennis
What is the status of the new version DataAssist?
Wampserver has reduced its available downloads. It is now only available with PHP : 5.5.12. So I am now plagued with the error...
"Deprecated: mysql_pconnect(): The mysql extension is deprecated and will be removed in the future: use mysqli or PDO instead in ..."
When previewing any pages with DataAssist database connection.
Dennis
edit the php.ini file to turn off depricated warnings:
error_reporting = E_ALL & ^E_DEPRECATED
Dennis
Thanks Jason,
I would still appreciate a status update on the new DataAssist, will it be available in a month or two, next year?
Dennis
At this point we are working an a MySQLi extension. After that is complete, the plan is to start work on Data Bridge.
I do not have a time frame or any other details though.
Dennis
Jason,
As I understand your suggestion above, I changed (in the Wampserver PHP.ini)
to
my problem went from an error message at the top of the page, to a Fatal error: Call to undefined function mysql_pconnect() in...
In an otherwise blank page
make sure that the mysql library is enabled in the php.ini settings.
Dennis
Yes it is.
Is...
the setting I should use?
If I change it to...
error_reporting = E_ALL & ~E_DEPRECATED
with a tilde instead of a caret, the page appears correctly (I believe).
Ok, then use that syntax.
