Search Wizard not finding results - %5B%5D
Thread begun 5/21/2014 2:11 am by djellis267466 | Last modified 5/21/2014 10:08 am by Jason Byrnes | 2203 views | 3 replies |
djellis267466
I have used DataAssist Wizard to create a Search page and a Results page. One of the items (called Category) is a multiple selection list. The URL string passed to the Results page includes the %5B%5D coding for left and right bracket (see below) but this does not generate any search results.
If I manually edit the URL string to remove the %5B%5D then the correct results are displayed. I do want to have multiple selections for Category - can you explain what is going wrong please ?
?ItemType=Photograph&Category%5B%5D=Village&
djellis267466
Details needed for suport
Jason, thanks for your help - the details are in the private section.
on the search page, i removed the [] brackets from the name.
i changed:
name="Category[]"
name="Category"
the [] brackets are needed for a form that uses the post method with a multiple select list, but not for a form that uses the get method.
