Email validaton with top-level domains
Thread begun 5/18/2014 10:14 pm by quy355499 | Last modified 5/19/2014 9:59 am by quy355499 | 1440 views | 2 replies |
quy355499
http://www.iana.org/domains/root/db
Email validation fails with some of the top-level domains listed in the above link such as .photography. How to fix the email validation so it will pass with all the top-level domains listed? Thanks.
Is tis using server side validation?
in the webassist/form_validations/wavt_scripts_php.php fiile
the following line sets the Known TLDs for email address validation:
$knownDomsPat = "/^(com|net|org|edu|int|mil|gov|arpa|biz|aero|name|coop|info|pro|museum|cat|\w{2,2})$/";
you an add additional TLDs to the that line
quy355499
It is server side validation.
That is a lot of domains to add manually :-P
I assume that this is the only solution.
