Sending information using email
Thread began 5/18/2014 2:00 pm by The Flying Fox | Last modified 5/20/2014 1:37 pm by The Flying Fox | 1597 views | 5 replies |
The Flying Fox
I want to send information to users with all the data added by them that is held in our database so they can fill in information that may be missing.
I tried the email system using the TO: recordset loop but it sends only the first held record to every user email in my system, this is not what I wanted to achieve.
Can anyone help
see post 2 in this thread for information:
http://www.webassist.com/forums/posts.php?id=17869
The Flying Fox
Thanks Jason, I did see this thread earlier but must have just glanced over it.
The Flying Fox
I have tried this method and cannot get any information to be placed into the email. My email is sent OK but no info is placed within
I have attached the form page and waue_ page for you to take a look at and tell me where I am going wrong.
Andy
approved.php
waue_approved_1.php
you have the syntax slightly wrong:
$RecipArray[$RecipIndex][0]["[trader_first_name]"]
should be:
$RecipArray[$RecipIndex][0]["trader_first_name"]
the square brackets are not needed inside of the quotes.
Ray wad used them in his example as a way of denoting a variable. So:
[yourColumnName]
should be replaced with your column name:
trader_first_name
The Flying Fox
thanks Jason,
I just copied the example in #2 from the link you gave me not realising it was slightly out of context.
Who knew it could be that simple.
Andy
