which line must be in my profil page to be in a session
Thread began 5/18/2014 5:32 am by jmuy76493762 | Last modified 5/20/2014 8:50 am by Jason Byrnes | 1969 views | 5 replies |
jmuy76493762
Hello
I can't find the good way to put my profil page in the session of my login page.
<?php @session_start(); ?>
<?php require_once( "../../webassist/security_assist/helper_php.php" ); ?>
if (!WA_Auth_RulePasses("Logged in to users")){
WA_Auth_RestrictAccess("../pages3a.html");
if (isset($_SESSION['SecurityAssist_UserID'])) {
Not sure that's this lines are correct and need also to have eventually the name of the visitor somewhere on my page so to be sure that all is working correctly.
I hope you can help me.
Best regards
I don't follow. a page should not be stored in a session.
Can you please provide more details on what you are trying to accomplish.
jmuy76493762
the profile page should be "in a session"
you can use the user ID session variable to filter a recordsert set to display the logged in users information.
create a recordset, set it to filter the user ID column using the session variable created by the login, then use the recordset binding to populate the page.
if you use the security assist wizard to create the pages, it will generate the users profile page automaticly.
jmuy76493762
Glad to hear it is working.
