I have moved server and the HTML editor does not now show - I have uploaded all relevant files - the server is IIS7 if this has any bearing
Thread begun 5/14/2014 7:53 am by alib75702 | Last modified 12/05/2014 12:19 pm by Sweens | 9448 views | 30 replies |
alib75702
I have put a very simple sample up here - nothing complicated - just the editor with nothing messed with - I need to get this sorted as a matter of urgency as it is on a system almost ready to go live
Some of the ckeditor files are missing form the server. see PM for additional details.
alib75702
how odd - I had installed and moved the files - and they weren't there locally - ah well - sorry to have wasted your time and thank you for your lovely quick response
you're welcome.
Sweens
Hi Jason
I have also moved the site to a new server. The html editor window dosplays fine and tex/style updates work.
However, when you go to insert an image or file, then 'browse server', the file manager window opens, but no thumbnails are displayed, nor subfoldrs that have previously been created.
When you click the 'browse for file', select a file, then 'upload', nothing appears to happen and the winsow remains blank. If you try to upload the file again, you get a message to say the file already exists - even though you can't see anyting anywhere!
I have uploaded all the webassist files, the database tables and everything else I can think of - but haven't changed any odf the web assist files, thinking 'it worked before...'
Any ideas?
many thanks, as always
Chris
Sweens
pm
Yes, the side bar will show all subdirectories, there is not a way to determine which subdirectories belong to a specific ID.
Sweens
pm
I need to see this in order to trouble shoot,
