wa_randompassword.php not being generated
Thread begun 5/13/2014 10:01 am by info4753 | Last modified 5/13/2014 12:54 pm by Jason Byrnes | 2395 views | 3 replies |
info4753
When I create a form with DA and try to add a Random Passwort via Security Assist, no code is being generated and no links to additional filed is created on the page. Using Mac DW CC newest WA extensions installed.
wa_randompassword.php and the whole folder security_assist is not being generated. I have to copy it manually from another project and link it in the form file.
<?php require_once( "../../webassist/security_assist/helper_php.php" );?>
require_once("../../webassist/security_assist/wa_randompassword.php");
are missing inside the file
I am not able to reproduce.
There are 2 steps to using the random password:
1) Create the random password binding
2) use the random password as the value for a form element.
The code wont be generated for step 1, but should be generated when you use the binding in step 2.
info4753
That's exactly what I did ...
I have tried a number of times to reproduce this using DW CC on Mac and other DW Platforms, But cannot reproduce.
I will log a bug for the problem but will have to add a note that I cannot reproduce.
