Installation diagnostic check says cURL not installed, but it is
Thread begun 5/13/2014 12:39 am by Mags | Last modified 5/13/2014 9:47 am by Jason Byrnes | 3523 views | 7 replies |
Mags
I can't get PowerCMS to install on a site on our dedicated server. I have already installed it on other domains on the server in the past with no problems. When I get the Diagnostic page, everything checks out except for:
"cURL is not installed. Contact your hosting provider to have cURL installed"
I contacted our server provider anyway and asked them to install cURL, which they have done (I've double-checked using phpinfo). I removed all the PowerCMS files locally and from the server and started the installation process again, but still getting the same error. Can you help?
Margaret
When it tests the cURL install, it tries to make a cURL post to the webassist site. your server must be blocking the cURL Post to our site.
Use this code to test the curl installation and make sure it can make a post to the webassist site:
error_reporting(E_ALL);
$c = curl_init();
curl_setopt($c, CURLOPT_URL, "https://www.webassist.com/");
curl_setopt($c, CURLOPT_TIMEOUT, 90);
curl_setopt($c, CURLOPT_POST, 1);
curl_setopt($c, CURLOPT_SSL_VERIFYPEER, 0);
curl_setopt($c, CURLOPT_RETURNTRANSFER, 1);
curl_setopt($c, CURLOPT_POSTFIELDS, "");
$result = curl_exec($c);
if(!curl_errno($c)){
$info = curl_getinfo($c);
echo 'Took ' . $info['total_time'] . ' seconds to send a request to ' . $info['url'];
} else {
echo 'Curl error: ' . curl_error($c);
Mags
Hi Jason, it seems to be fine - it returned this:
Took 0.719566 seconds to send a request to https://www.webassist.com/
I just tried to load the /install_cms page again and this time I just got a blank page - it didn't even redirect to the diagnostic.php page. The link is in the PM section.
Mags
Details in the PM section.
See PM
Mags
Ah, fixed it - the PowerCMS connection was using the server IP address which Dreamweaver could connect to no problem, however changing it to localhost allowed the PowerCMS installation to connect. Now installed, thanks!
you're welcome.
