Invalid JSON error when sending
Thread begun 5/09/2014 12:30 am by jebrandon343719 | Last modified 5/16/2014 1:22 pm by Jason Byrnes | 3452 views | 7 replies |
jebrandon343719
Each time I send an email blast, I get an Invalid JSON... error. I have read forums and checked all the emails to ensure they are valid!
I dont know if the message has been delivered to all recipients or not!.
see screen shot.
Can you tell me what this means?
jebrandon343719
Thanks Jason, see private message
See PM
jebrandon343719
see below
I am not able to reproduce.
I just tested the jb mailing, and it completed without an error.
jebrandon343719
Do You have any clues?
Your test was with 1 email address. This error is occurring when there is a database of about 100 records.
Could it be a bad record? Is there limits on number of emails?
Any limits tot he number of emails will be imposed by the server.
you should check with the server to ask about limits on sending emails using PHP
It is certainly posible that it could be a bad email address in your mailing list. does it always stop at the same point in the mailing?
To be able to troubleshoot, I would need a test mailing set up that demonstrates the problem, I need to be able to reproduce the problem in order to troubleshoot the cause
