Date Validation using DataAssist
Thread begun 5/08/2014 6:24 pm by laboy390110 | Last modified 5/09/2014 12:52 pm by Jason Byrnes | 4986 views | 13 replies |
laboy390110
I'm trying to validate a date field with min and max dates. I followed the instructions posted in your WebAssist Help System, with no success. This is the code DataBrigge generates:
$WAFV_Errors .= WAValidateDT((isset($_POST["hex_Fecha_Instalacion"])?$_POST["hex_Fecha_Instalacion"]:"") . "",true,".*","mktime(0, 0, 0, date(\"m\") , date(\"d\")-7, date(\"Y\"));","mktime(0, 0, 0, date(\"m\") , date(\"d\")-0, date(\"Y\"));",true,".*","","",true,10);
Min Date = current date - 7 days
Max Date = current date
Please see line 21 of the attached file.
Please advice...
José
it looks like you are entering the min and max dates as php without including the php brackets:
mktime(0, 0, 0, date("m") , date("d")-7, date("Y"));
try entering it as:
<?php echo(mktime(0, 0, 0, date("m") , date("d")-7, date("Y"))); ?>
instead.
laboy390110
Nop, it doesn't work as suggested. The code I'm entering is straight from the WebAssist Help System, using WA Server Validations interface. Please see attachment... If I enter the dates as static (MinDate = 05/0/2014, MaxDate 05/09/2014) it will work. The problem is when using dynamic values.
use this code for the min date:
<?php echo(date("m/d/Y", mktime(0, 0, 0, date("m") , date("d")-7, date("Y")))); ?>
and enter this for the max
<?php echo(date("m/d/Y")); ?>
I will forward this to the documentation team also.
laboy390110
Nop, it doesn't work. Probably this can help you:
If I enter a static date value with the Validate Time "checked", the validation fails. It only works with the Validate Time option "unchecked". The WebAssist Help System mentions that in some instances both check boxes should be selected. Obviously, everything that I try, I check it both ways. Probably the script is having problems validating this mktime function. I look at it and everything seems ok to me. I have no idea. Please advise...
your date picker does not pass the time. In the case of a date picker, you need to leave the validate time option unchecked.
laboy390110
Ok, with the option unchecked it doesn't work
laboy390110
Please see private message...
see PM,
