bug in ecart when adding discount rule
Thread began 5/03/2014 1:11 am by CraigR | Last modified 5/04/2014 4:29 am by CraigR | 491 views | 2 replies |
CraigRBeta Tester
I am adding a custom expression as a discount trigger in ecart 6.
For example, if I type
$this->TotalColumn("TotalPrice") >= $_SESSION['couponthreshold']
as a condition,
the "TotalPrice" string has escape slashes added to it, so it appears as follows...
$this->TotalColumn("/TotalPrice/") >= $_SESSION['couponthreshold']
use single quotes:
$this->TotalColumn('TotalPrice') >= $_SESSION['couponthreshold']
CraigRBeta Tester
Hi Jason,
That will work,
the only reason I noticed the error it is that I picked up the condition from a site I wrote using an earlier version of ecart and copied it across.
I got away with the double quotes before,
