Issue with recordset
Thread begun 4/30/2014 1:57 pm by hbibizadeh396670 | Last modified 5/01/2014 10:24 am by Jason Byrnes | 3204 views | 7 replies |
hbibizadeh396670
I have a user registration system and I created a forum.
I have a ForumAccess record set on this page and am using show if regions to either show a login message or the forum posts themselves.
This issue is that the recordset is not filtering at all and is returning 0 results... don't understand why this is.
Thanks in advance
hbibizadeh396670
See PM
hbibizadeh396670
Thank you please see the PM
the forum access recordset is set to filter using the UserID session variable which does not exist.
the session that is created by the login is named:
SecurityAssist_UserID
hbibizadeh396670
Thank you so much... it works
you're welcome.
