Edit shopping cart created eCart 5 Dreamweaver 5.5 using eCart 6 Dreamweaver CC ?
Thread begun 4/30/2014 8:49 am by pat346841 | Last modified 5/06/2014 9:30 am by Jason Byrnes | 6285 views | 15 replies |
pat346841
Is it possible to edit a shopping cart I created with eCart 5 and Dreamweaver 5.5 in Dreamweaver CC with eCart 6?
Yes, you can use eCart 6 to edit a cart created with eCart 5.
and you can use DW CC to edit sites created with DW CS5.5
pat346841
Dual Environments
Currently I have Dreamweaver CS 5.5 and CC installed. Should I uninstall cs 5.5 / eCart 5 before installing eCart 6 to Dreamweaver CC?
you c an keep DW CS5.5 with eCart 5 installed along DW CC with eCart 6 installed.
you just cant install eCart 5 and 6 in the same version of DW together.
pat346841
One Last Question (Hopefully)
I have the extensions installed into Dreamweaver CC. In the old version there was a tab with a GUI that told you what cart you were working on and gave you a few options. How do I get that to display in the new version?
to open the eCart object panel, go to WebAssist -> eCart -> eCart Object
pat346841
I created the new checkout process with the payment gateway we chose to use. Created a new Add to cart button on a product page. When I try to click add to cart I get this error:
Warning: Missing argument 13 for eCartSL_Definition::eCartSL_Definition(), called in /home/web/users/1773.admin12/sites/dev.shotlock/public_html/WA_eCart/eCartSL_PHP.php on line 339 and defined in /home/web/users/1773.admin12/sites/dev.shotlock/public_html/WA_eCart/eCartSL_PHP.php on line 4
Warning: session_start(): Cannot send session cache limiter - headers already sent (output started at /home/web/users/1773.admin12/sites/dev.shotlock/public_html/WA_eCart/eCartSL_PHP.php:4) in /home/web/users/1773.admin12/sites/dev.shotlock/public_html/WA_eCart/WA_eCart_Definition_PHP.php on line 465
Warning: Cannot modify header information - headers already sent by (output started at /home/web/users/1773.admin12/sites/dev.shotlock/public_html/WA_eCart/eCartSL_PHP.php:4) in /home/web/users/1773.admin12/sites/dev.shotlock/public_html/ShotLock_Shotgun.php on line 42
Make sure to open the cart object window, click the edit button for the eCart object and click OK to have it updated to eCart 6.
pat346841
I did what you said, now I get this...
Warning: require_once(webassist/forms/persist.php): failed to open stream: No such file or directory in /home/web/users/1773.admin12/sites/dev.shotlock/public_html/cart/cart.php on line 1
Fatal error: require_once(): Failed opening required 'webassist/forms/persist.php' (include_path='.:/usr/local/php-5.5.9/lib/php') in /home/web/users/1773.admin12/sites/dev.shotlock/public_html/cart/cart.php on line 1
that error means the webassist/forms/persist.php file has not been uploaded to the server.
