Registration page not inserting new record
Thread begun 4/29/2014 9:11 am by rob75685 | Last modified 4/29/2014 10:05 am by Jason Byrnes | 805 views | 1 replies |
rob75685
hi there
Could you help me please. I built a site a while back using a registration form with various validations, once validated a new record was inserted.
I've had to move the whole site to a new location, and I've copied over everything. The validations still work but for some reason the new record is not inserted...
Could you take a look please ?
http://www.rtmedia.co.uk/myhousefile/registercode.php
files attached
thanks for your help
When moving the site, you will have to also move the database. this means a new database would need to be created on the new server and the tables from the old server recreated through an export of the old database tables and import to the new database.
also, you would need to edit the database connection details so it is connecting to the new server.
if the insert isn't working, my suspicion is that the connection has not been updated or the tables dont exist.
