Joinng 2 MySQL tables
Thread begun 4/28/2014 1:47 pm by Armen | Last modified 5/06/2014 1:25 pm by Jason Byrnes | 3160 views | 12 replies |
Armen
Not sure if I'm doing this correctly...
The two tables are Suppliers (houses all suppliers) and delMenu (houses delivery postal codes, fees, etc).
I need to join two tables (suppID is the common filed in both).
I have a recordset (rsDelMenu) that lists all records in delMenu that match two variables posted from the form on the previous page. I now need to merge the results of this recordset with all records in the Suppliers table, where suppID = suppID
=== rsDelMenu ===
$colname_rsDelMenu = "-1";
if (isset($_POST['serviceType'])) {
$colname_rsDelMenu = $_POST['serviceType'];
$colPC_rsDelMenu = "-1";
if (isset($_POST['Postal_Code'])) {
$colPC_rsDelMenu = $_POST['Postal_Code'];
mysql_select_db($database_connData, $connData);
$query_rsDelMenu = sprintf("SELECT * FROM delMenu WHERE serviceTypeID = %s AND delPC = %s", GetSQLValueString($colname_rsDelMenu, "int"),GetSQLValueString($colPC_rsDelMenu, "int"));
$rsDelMenu = mysql_query($query_rsDelMenu, $connData) or die(mysql_error());
$row_rsDelMenu = mysql_fetch_assoc($rsDelMenu);
$totalRows_rsDelMenu = mysql_num_rows($rsDelMenu);
see this page for details on creating a sql join query:
http://www.w3schools.com/sql/sql_join.asp
Armen
I took a look at the page Jason. Thank you. However, I'm kinda stuck when it comes to filtering the joined tables based on the two variables posted by the form on the previous page...
I'm thinking the easiest thing would be to update this recordset to a Join?
$colname_rsNeo = "-1";
$colname_rsNeo = $_POST['Postal_Code'];
$colType_rsNeo = "-1";
$colType_rsNeo = $_POST['serviceType'];
$query_rsNeo = sprintf("SELECT * FROM delMenu WHERE delPC = %s AND %s = serviceTypeID", GetSQLValueString($colname_rsNeo, "text"),GetSQLValueString($colType_rsNeo, "int"));
$rsNeo = mysql_query($query_rsNeo, $connData) or die(mysql_error());
$row_rsNeo = mysql_fetch_assoc($rsNeo);
$totalRows_rsNeo = mysql_num_rows($rsNeo);
yes, update the recordset to a join, and do not change anything for the where clause.
Armen
Where exactly should I put JOIN code? I keep getting an error...
Armen
Never mind. Got it. Thanks, Jason. As always, your help is greatly appreciated!
Armen
I have setup a JOIN. However, the filtering does not seem to be working. All records show up...
SELECT *
FROM delMenu INNER JOIN suppliers ON delMenu.suppID=suppliers.suppID
WHERE delPC = colname AND colType = serviceTypeID
colname gets runtime value from: $_POST['Postal_Code']
colType gets runtime value from:$_POST['serviceType']
Am I approaching this correctly?
looks correct, send a copy of the page and a link where i can see the problem.
Armen
p/m
Armen
It looks like the repeat region might be the issue...???
The same menu seems to be repeating a few times...
