JQuery Form validation CSS overwrites DA Button CSS
Thread begun 4/28/2014 8:38 am by info4753 | Last modified 4/28/2014 9:02 am by info4753 | 1829 views | 4 replies |
info4753
When I set the same preset name for DA Buttons and JQuery Form validation, then the JQuery Form validation overwrites the Button CSS. In my case it's the background color. Can you please fix this with the next update?
CSS Button:
form.MyCompany_CustomerWebsite input.formButton.CustomerWebsite {
background-color: #0026d1;
CSS JQueryValidation:
.CustomerWebsite {
background:#610a0f; /* default background for browsers without gradient support */
If you use the same preset name, it will overwrite the CSS, use a unique preset name to prevent this.
info4753
Thanks Jason.
I know (now after searching the problem for an our) but this should be taken over from the extension I'd say. Or is this mentioned in the documentation?
By the way, using a name like
btn-Mycompany
Doesn't work and throws an error, btnMyCompany works
If you use the same preset on 2 pages, it seems to me that you would want both to use the same settings.
That is the job of the presets, to offer a way to easily apply the settings to multiple pages in the site.
I Will log a bug on the preset names.
info4753
As I use your software for different projects, I use the customer name for each preset part. In your examples your are not using names like btnMyCustomer and valMyCustomer but MyCustomer too. I think this is misleading and that's why I used MyCustomer for each part too. ;-)
