Click on PayPal Checkout goes directly to checkout_failure.php
Thread begun 4/28/2014 7:49 am by joerg431091 | Last modified 5/07/2014 12:28 pm by Jason Byrnes | 5084 views | 40 replies |
joerg431091
I have above problem on 2 sites while trying to checkout with PayPal - one is using eCart 5 and one is using eCart 6.
For the eCart 5 site = Clicking on the "Checkout with PayPal button leads directly to the pp_checkout_failure.php page. I have included the paypal credentials in the checkout.php page as well as in the pp_confirm.php page
For the eCart 6 site = After choosing PayPal as a payment option, entering the shipping information and clicking on the continue button = leads to a redirect to the checkout_failure.php page. I have included the paypal credentials in the Gateway Credentials server behavior in the confirm.php page.
I also called PayPal to confirm our API Signature Credentials such as Username, Password and Signature. They seem to be correct.
What am I missing?
Thanks for any ideas.
Joerg
on the pp_checkout_failure page, add the following code in the page body to write the session contents to the page:
<?php @session_start(); var_dump($_SESSON); ?>
the session contents will include the response from paypal with info on the cause of the failure.
joerg431091
Hi Jason,
Thanks for getting back so quickly. I already did this but forgot to include the attachment.
I will add the attachment now.
Thx.
Joerg
the PDF is showing info from Authorize.net, not from paypal.
joerg431091
I know - I thought that is strange too but the error I attached did occur while choosing PayPal as a checkout option.
Ok, that's fine.
when changing the gateway that is used, make sure to delete the existing checkout pages before running the checkout wizard again to recreate them.
joerg431091
Thanks Jason.
Do I simply delete the old checkout pages and then just run the wizard again or do I have to do anything else such as uninstall anything or change any settings?
yes, simply delete the existing checkout pages, then run the checkout wizard to recreate them.
joerg431091
Hi Jason,
I did delete the old checkout pages and did run the checkout wizard again. I had it working on my local machine (did not test whether the transaction goes through with paypal) but the site connected and the option to pay with paypal came up.
Now, after embedding the code in my site template I have 2 problems:
1 = If I test it locally and choose papal as a payment option I am immediately referred to the checkout_failure.php page. Is it possible that there might be a conflict with another css code or so in the template? Because I believe it did work before I embedded it into the template code.
2 = I can not test it on the remote server because once I try to choose paypal as a payment option, enter shipping information and clicking continue = the page goes gray but no loader appears and page does not change or connect. I was looking all morning to see whether I am missing a file on the remote server but it looks like everything is uploaded correctly.
Checkout with AuthorizeNet works perfect.
Any help is appreciated.
Thanks a lot and best regards,
Joerg
