ERROR! variable: totalRows_WADA error - repeatedly.
Thread begun 4/23/2014 4:24 pm by bblue | Last modified 5/05/2014 9:20 pm by bblue | 3882 views | 8 replies |
bblue
i am getting "variable: totalRows_WADA*" error on any results page created with dataassist, where the * is the name of recordset - "variable: totalRows_WADAproducts," for example. i have tried many times and many remedies:
i have uninstalled and re installed databridge, deleted win cache file, deleted configuration folder, in every order and combination thinkable.
i did not make any changes prior to this that may have caused error.
i tried different presets within dataassist - create pages - all with same result. (the error did not appear only when Search was not included.)
i read a post where the answer was to move the recordset code to BEFORE the code that uses the variable - and that result is when viewed in Live View, the error is gone, BUT - all the relevant server behaviors still have red exclamation point, and the behaviors nor the bindings panels, still dont think there is a recordset. and, even if that solution were usable, the problem is still created every time i attempt.
I hope you can help me out, this has been very exhausting and frustrating.
i have windows 8.1, dreamweaver CC, newest install Databridge.
So it seems after i have tested this error and tried so many different scenarios, that the broken code is created when there is not a search page included. and the results page is always broken, and shuffling the recordset code does not fix it.
attached is an example of this, where i pasted the rs code earlier, but yet, still get many red exclamations (see the image.)
thanks in advance,
exhausted ben
Please provide a Skype username or a US phone number and a good time to contact you when you will be in front of your computer and we will have an engineer contact you to resolve this issue over the phone.
We are available Monday - Friday from 9am - 4pm EST (except major U.S. holidays).
bblue
thanks, will do!
bblue
Jason - thank you for the support.
so, after re-installing Dreameaver CC, deleting cache, configuration folder, and re-installing extensions one by one (and DataBridge always after eCart), and finally, DataAssist creates the pages without misplacing the rescordset code and creating the red exclamations in the server behaviors panel. great!
but one problem in the code remains - when testing the results page, remote or testing server, when you click on the link to show the next page of records, something is broken - look under the image - just click the link to show next page or records - http://datamoguls.com/WADA/products_results.php. its persistent, happens every time.
thanks again for helping.
send a copy of the results page please.
bblue
thanks - i will have all that posted back to you soon, thank you!
bblue
here is the results page.
change the following code:
<a href="products_detail.php?ProductID=<?php echo($row_WADAproducts_3['ProductID']); ?>" ><?php echo(isset($_GET["pageNum_WADAproducts_3"])?"&pageNum_WADAproducts_3=".intval($_GET["pageNum_WADAproducts_3"]):""); ?>
<a href="products_detail.php?ProductID=<?php echo($row_WADAproducts_3['ProductID']); ?><?php echo(isset($_GET["pageNum_WADAproducts_3"])?"&pageNum_WADAproducts_3=".intval($_GET["pageNum_WADAproducts_3"]):""); ?>" >
do you have the most recent data Bridge version installed? the most recent version is 1.1.9
bblue
thanks, that code edit you posted was perfect. And yes, i have latest Databridge. Moving forward i'll report back here if these problems persist, or are clean and gone.
