Using Dreamweaver 13.2 rev 6466 on Mac Lion: upgrade to eCart6 and DataBridge 1.1.9 not working
Thread begun 4/22/2014 6:28 pm by beaded | Last modified 5/01/2014 11:31 am by Jason Byrnes | 2905 views | 9 replies |
beaded
I uninstalled the older versions —eCart 5 and DataBridge 1.1.4. Installed the latest eCart6.06 and DataBridge1.1.9. At first, it seemed eCart installed but the cart selector was grayed out, and all references were to eCart 5. DataBridge 1.1.9 wasn't able to be called on with any insert method into a basic .PHP file.
Tried:
• Layout resets
• Uninstall and reinstall
• removing the .dat file
• removing stuck/dated WA_Installer installed/mxi and installing/xml files
Nothing works. Any solutions or step orders I've missed?
Try recreating the users configuration folder as outlined in step 12 of the Adobe troubleshooting guide:
http://helpx.adobe.com/dreamweaver/kb/troubleshoot-javascript-errors-dreamweaver-cs4.html
The in the extension manager, uninstall the extensions, and install them again.
Make sure you install the Server Behaviors panel extension first:
http://www.webassist.com/tutorials/Server-behaviors-for-Dreamweaver-Creative-Cloud
after that one is installed, open DW and close it before installing the others.
after installing eCart and Data Bridge to the extension manager, open DW and a PHP page start the WebAssist installer. When the WebAssist installer completes, don't forget to restart DW.
beaded
Hi. Thanks.
Uhm. I've tried 7 times at this point, adding possibly silly variations after the initial standard try —things like closing Extension Manager each time after the two installs, or restarting the computer.
What happens that is different from your description of the process is that the modal (?) window of WebAssist's finishing installer starts BEFORE I can open up a .php page (although a page might be opening automatically behind the greeting screen). DataBridge goes though the 1-2-3 stages, then eCart6 goes through the 1-2-3 stages. I click DONE and restart. This last time I tried, I at least got a response after selecting the DataAssist Wizard (see attached pic). Just mousing over the drop-down selector for eCart produces the same javascript error (see above, initial pic).
I tried removing a non-WebAssist extension, and doing the WebAssist installs several times. Made no difference.
My method exactly was:
1) Uninstall all extensions
2) Rename the configurations folder
3) Install Deprecated Server Behaviors 1.0
4) Open DW then quit DW
5) Install eCart6 first, then DataBridge 1.1.9 second —one immediately after the other
6) Open DW and watch the install finishes. Quit DW.
7) Reopen DW. Try to use a WebAssist product within DW.
I have DW preferences to open php pages by default.
Can't think of any other details. What should I try next?
Thank you.
Please provide a Skype username or a US phone number and a good time to contact you when you will be in front of your computer and we will have an engineer contact you to resolve this issue over the phone.
We are available Monday - Friday from 9am - 4pm EST (except major U.S. holidays).
beaded
Skype username, US phone number, time to contact provided in PM. Thanks.
See PM
beaded
See PM.
I have been online between 9am and 5pm since monday, not sure why you are not seeing me on skype.
would you be available tomorrow (Thurdsay, May 1st) around 2pm EST?
beaded
see PM
This was a problem caused by using an apostrophe in the Mac OS hard drive name.
