Email depending on value in registration form
Thread begun 4/22/2014 8:40 am by Mags | Last modified 4/22/2014 12:34 pm by Mags | 2964 views | 8 replies |
Mags
I have built a user registration system using SecurityAssist which requires admin approval before the user can access the site. Everything's working great, but I have two admin people, one who gets emails letting them know when anyone registers, and the other who should only get an email if the "Member_Type" dropdown selection in the registration form is a specific value. I have two Universal Email behaviors set up, one for each Admin person, but currently the trigger is "any form post", so both admins get all registration emails. I see I can use a dynamic value but I'm not sure how to construct it. Basically I only want to send an email to the second admin person if the Membership_Type dropdown field in the form's value is "3", so would this be the correct syntax?
((isset($_POST["Membership_Type"]))?$_POST["Membership_Type"]:"3")
Margaret
the code for the trigger if statement would be:
if((isset($_POST["Membership_Type"])) && $_POST["Membership_Type"] == "3") {
Mags
Hi Jason
It didn't work unfortunately - it stopped the registration page from loading (just got a blank page). I've put the FTP details in the PM section, could you maybe take a look for me?
Margaret
Sorry, there was a syntax error in the original code, the correct code should be:
Mags
Hi Jason
It's still not working - getting a blank page when trying to load the registration page. Could you take a look?
Margaret
at line 255, you have:
if (((if((isset($_POST["Membership_Type"])) && $_POST["Membership_Type"] == "3") { != ""))) {
it should be:
Mags
I've replaced that line and it's now working fine, thanks. I don't know why it was wrong though - I copied and pasted the code you gave me into the Universal Email Server Behavior Trigger dialog box so it must have got rewritten somehow.
Thanks again
Margaret
you cant copy that code into the trigger box of the UE behavior. What you are asking for cannot be done in the behavior, it has t be done manually directly in the code.
Mags
Ah, I didn't realise - all working now though, thanks!
