Ecart checkout chdir error
Thread begun 4/20/2014 4:26 pm by ed331947 | Last modified 4/21/2014 1:19 pm by ed331947 | 2423 views | 5 replies |
ed331947
When I checkout not using https, everything works fine. However, I am using a 'shared' ssl which gives a different url. Everything works fine until I go to submit client information and the payment page is requested. When I do that, I get the following:
Warning: chdir() [function.chdir]: No error (erno0) in D:\.....\webassist\framework\ajax.php on line 22
ed331947
See PM
ed331947
PM
This is being caused by a php bug when used under IIS. see this past for details:
https://bugs.php.net/bug.php?id=43977
using phpinfo() i see your php version is 5.2.17
either, change the hosting account to a Linux account using Apache, or have the host update the php version.
NOTE: where you are using shared hosting, you will need to pass the cart contents to the secure server from the c art page.
see this page for more details:
http://www.webassist.com/tutorials/Secure-Socket-Layer-SSL-and-eCart-sites
ed331947
Thank you. Passing the product thru the cart to the checkout did work. Thanks so much for your help.
