not passing to paypal when hitting checkout
Thread begun 4/16/2014 2:53 pm by mike-j-taylor318947 | Last modified 4/18/2014 9:45 am by Jason Byrnes | 4438 views | 13 replies |
mike-j-taylor318947
static cart item added, then go to check out, fill in address details, when you hit check out the page flashes but doesn't go anywhere and the form is empty. this is on a live site www.theinsolecompany,co.uk.
any ideas
mike-j-taylor318947
pm
looking at the source of your checkout page, there are a number of problems I see, the first seams to be a problem in your template.
at the very top, there are 2 doctype and HTML tags:
<!DOCTYPE html>
<html>
there should only be one.
further down, there is an opening head tag, then another opening head tag with out a closing head tag:
!-- InstanceBegin template="/Templates/grid.dwt" codeOutsideHTMLIsLocked="false" --><head>
<script src="webassist/progress_bar/jquery-blockui-formprocessing.js" type="text/javascript"></script>
<link href="webassist/forms/fd_newfromblank_default.css" rel="stylesheet" type="text/css" />
<link rel="stylesheet" href="webassist/jq_validation/Bloom.css" />
<script src="//ajax.googleapis.com/ajax/libs/jquery/1/jquery.min.js"></script>
<script src="//ajax.googleapis.com/ajax/libs/jqueryui/1/jquery-ui.min.js"></script>
<link href="WA_eCart/CSS/eC_Checkpoint_Custom_Arial.css" rel="stylesheet" type="text/css" />
<link href="webassist/forms/fd_cool_default.css" rel="stylesheet" type="text/css" />
<link rel="stylesheet" href="webassist/jq_validation/Midnight.css">
<link href="webassist/forms/fd_cool101_default.css" rel="stylesheet" type="text/css" />
<style type="text/css">
@import url("css/main.css");
</style>
<head><a name="backup"></a>
there should be only 1 opening head tag.
the closing head tag is down the page by the body:
</head>
<body class="products_results">
the opening head tag in the middle needs to be removed.
also, there are multiple code blocks for the jquery validation. This suggests that you ran the checkout wizard multiple times. If you need to re runn the checkout wizard, you should first delete the checkout pages to prevent duplicate code from being added.
all the duplicate code is causing conflicts and causing the validation on the page to fail.
Delete the existing checkout pages and rerun the checkout wizard to recreate them, and edit the template to remove the duplicate HTML tags.
mike-j-taylor318947
pm
you removed the country select list from the checkout form which is required.
mike-j-taylor318947
pm
In the checkout form, remove the onBlur event from the phone number field:
onblur="WAValidatePN(document.getElementById('CheckoutWizard_Cool101_Default').Phone_Number,'',false,true,' xxxxxxxxxxx',document.getElementById('CheckoutWizard_Cool101_Default').Phone_Number,0,true);MM_validateForm('Phone_Number','','R');return document.MM_returnValue"
The state field cannot be removed, it is needed to fill in the form even if it is left blank.
mike-j-taylor318947
pm
looking at the source of the checkout page, I still see the onblur event. It has not been removed from the page that is on the server.
